Thank goodness for.
babcorp, Dec 9, 1:59pm
having a secondary fan belt.
I serviced my Courier diesel today and when I took off the cover plate underneath to drain the oil I found a chewed up fan belt.
I'm not sure how long its been broken. So will replace the lot while I'm at it.
I would hate to think of the damage that could have been done.
mugenb20b, Dec 9, 2:03pm
Yep, very lucky, a broken belt usually takes out the good belt as well. Would've been a $2000 job had you cooked it.
skin1235, Dec 9, 3:48pm
you have to replace the pair anyway, they're only the same size at purchase
and check them again in a fortnight, they'll need nipping up again - the rough surfaces will have worn down - loose belts last about a 1/4 of the time properly tensioned belts do
babcorp, Dec 9, 8:32pm
Yes skin, I've ordered the pair, and replacing cam and the power steering belts as well while I'm at it, they're just about due anyway.
