Vy
blackdotlova, Dec 10, 1:37pm
about to put new shocks x4 in vy commie ute any suggestion!
jmma, Dec 10, 1:47pm
Take the old ones out first (o:
hopie, Dec 10, 1:49pm
Thats some decent advice right there
jmma, Dec 10, 1:52pm
Thanks, but you could have given the next step (o:
How is it Tom(o:
blackdotlova, Dec 10, 2:13pm
Hi mark yeah all good this side, I'm starting to think you my have worked with my brother at manthels many years ago where countdown is now.
I'm looking towards KYB
jmma, Dec 10, 2:16pm
Yes I did, I was Foreman there. Just take your time with shocks, you will be fine. Just watch that the springs don't bite you (o:
blackdotlova, Dec 10, 2:24pm
yeah sweet as done afew over the years when i was at collins,did i tell you john passed away
blackdotlova, Dec 10, 2:25pm
do you feel i will need a wheel alinement (sp)
jmma, Dec 10, 2:43pm
Yeah.you did. Shouldn't need a wheel alignment for fitting new shocks, but in saying that, why not. New shocks, wheel align = new car (o:
Someone will be along soon that will be able to recommend decent shocks, good luck.
blackdotlova, Dec 10, 2:53pm
got one jacked up,as you say why not
kingfisher21, Dec 10, 3:47pm
You will need a wheel alignment as the front struts have to be removed which upsets the camber settings. I'd go for a set of Monroe Sensa-Tracs or GT Gas Reflex.
blackdotlova, Dec 12, 9:15pm
gentlemen i took the front struts out dismantled them and the top cover bearings fell out and are now all over the man cave floor, all 92 of them can i just buy thebearing top and bottom race with bearings as a sealed unit.
treachug, Dec 13, 5:27am
Yes you can buy the upper strut bearing. Common thing to happen - the bearings aren't sealed etc & stones & grit get up in there & also the hammering the bearings get, stuffs them. Your local Holden dealer should carry them in stock - we carry & sell them at work & we're not a Holden dealer.
Also check to see if you have the foam rings up where the strut sits.if you have check to see if they are ok & if nothing there get them as well. They help stop the stones & grit getting to the bearing.
blackdotlova, Dec 13, 11:16am
job done, wheel alignment at 3pm thanks for the advice
