Someone familiar with hondas
manifestdestiny, Dec 18, 10:52am
Needing a power steering pump for a 97 odyssey does anyone know if one from a 95 or 96 will fit.
Priced a new one from honda and they are over 1800 dollars.
phillip.weston, Dec 18, 11:18am
yes earlier RA1 models should fit. Look at CD Accords also.
manifestdestiny, Dec 18, 11:33am
Thank you, also one more question, if I disconnected the belt from the pump to drive the car to the garage will there be any danger of steering ceasing up or it there any chance it will it cause further damage
tuttyclan, Dec 18, 12:13pm
Whats the reason for replacement,is it leaking and/or making noises.
Have you had a quote to have your one rebuilt.
bellky, Dec 18, 12:17pm
Yep I agree, I 'rebuilt' the one in my Ford for $17.00 (seal kit).
I should probly say I had to buy a special tool to get the pulley off for 70 or 80 dollars, but was still cheaper than anything else.
manifestdestiny, Dec 18, 12:35pm
Well it was making a noise and had to use it yesterday to go pick up a bearing for it as I narrowed it down to the pulley bearing but while I was out it crapped itself and started spilling power steering fluid all over the place so guessing its stuffed now. Also if anyone can recommend who would rebuild them in chch!
vtecnet, Dec 18, 12:38pm
Just call Strong Honda or All Cars etc, they should have a second hand one cheap enough
