Will this redudce drag
inkapuka, Dec 30, 12:01pm
V X commy berlina has a low spoiler would you get better fuel if i took it off im sure its oly there for looks unlike the ss or hsv
a.woodrow, Dec 30, 2:11pm
Honestly I don't think it would make any measurable difference. Get a chip for it is the best way to reduce fuel consumption
johnf_456, Dec 30, 2:17pm
You would get more fuel economy by doing simple basic things such as making sure tyres are pumped up, brakes are not binding, removing roof rack, emptying the boot, checking the air filter, plugs, fuel filter. Making sure the engine is running at the correct operating temperature etc.
trogedon, Dec 30, 2:25pm
If it did get better fuel consumption (i.e. use less fuel) it would only be at the minimum (and above) speed that made it work properly. Probably not much use around town.
morrisman1, Dec 30, 2:31pm
The spoilers on cars are mainly for looks, They have very little lifting ability and their drag is also very low. Some designs will also reduce drag by reducing turbulent wake.
If you wanna reduce drag on your car then cover all un-necessary air intakes, seal edges, smooth the underbody as much as practical and fit a low bodykit which blocks air from entering the underbody of the car.
sr2, Dec 30, 3:23pm
Do not confuse a spoiler with a rear mounted wing. A spoiler is designed to ???spoil??? the laminar airflow at the rear of the car where as a rear mounted wing is designed to produce down force. When we were running the KOSEVO race car we had a problem with lift in the rear at high speeds, this would reduce castor on the front which would in turn scare the living daylights out of the guys inside the car! The problem was diagnosed as being aerodynamic lift in the rear being caused by pushing a mid 80??
msigg, Dec 30, 4:34pm
Gonna make no difference.
