"scoots" needs help
alski2, Dec 31, 10:23am
"scoots " i am a 2007 50cc i have a full belly of 91 and oil in me i turn over but only some times startthen i die with in 30 sec then dont start again for hours. i am sick i need help
dunedin_moto, Dec 31, 10:24am
What make of scoots would you be!
meathead_timaru, Dec 31, 10:40am
Flooding.
alski2, Dec 31, 10:52am
i am a suzuki sj50 , how does my rider fix the flooding! he sees the gas line and oil line mix into the same line. it only stared this 2 weeks ago and its only geting worse
meathead_timaru, Dec 31, 11:02am
It could be many things. Start with a new spark plug.
biddy6, Dec 31, 11:30am
Too much oil in the mixture !
tmenz, Dec 31, 11:33am
Muffler's clogged!
Spark plug's fouled!
desmodave, Dec 31, 12:17pm
Mufflers are often over looked on 2 smokes.
meathead_timaru, Dec 31, 12:20pm
But they don't usually get blocked over the course of just a couple of weeks.
gammelvind, Dec 31, 2:53pm
Oh yay the joys of small engines. Usually two things, fuel or spark.
Fuel. Disconnect fuel line, put end into a container, does it flow well and continuously when you turn tap on! Short bursts or dribbles, blocked tank/tap/hose.
Does the fuel get into the carb, blocked jets/neadles or crap in carb. Pull it apart carefully and clean everything,blow every little pipe and hole out.
Spark. Spark plug out, hold against head and turn over, do you get lots of continuous sparks! Replace plug anyway, small two strokes eat them. No spark! Lead, points, condenser stuffed.
I think from your description that you most likely have a fuel blockage. Buuuut without seeing it.
llortmt, Dec 31, 5:39pm
No more like stars, my head REALLY hurts!
llortmt, Dec 31, 5:42pm
CDI mate no points/condenser and that could be the problem fires until its warm, however I'd start at the plug.
gammelvind, Dec 31, 7:42pm
Don't forget to hold it on the head.
