i have a standard mk1 1300 sport with the standard 1300 gt engine whichs sits high at the front as most escorts do, i was thinking about lowering it maybe 2" at the front, I have found a 'lowered spring' supplier who as asked what diameter my springs are, 4 3/4" O.D or 5 1/4" O.D and also what poundage do i need!. to be honest i do not know this, is there a standered set,anyone done this before + would i need to alter the struts thanks for any help
serf407,
Jan 1, 12:20pm
How old are the rear leaf springs, do they need resetting or replacing !
What are the existing shock absorbers like, no leaks etc !
Rally Mk1 escorts are usually high in the back in a gravel spec.
jonthefisho,
Jan 1, 12:28pm
Look on here. listing 547591933
jasoo,
Jan 1, 2:04pm
Try Burton power in the UK. They are experts, just get the bits shipped over
pompey72,
Jan 1, 3:30pm
Hi Thanks for that, this seller has 2" lowering springs which are 175LB with 120MM O.D FIT,
is 175LB a common lowering spring for a factory standard mk1!
pompey72,
Jan 1, 3:34pm
the rear leaf springs look like factory original and the shocks don't leak as far as i am aware, this is a factory standard MK1 1300 sport in very original con so not for race/rally
pompey72,
Jan 1, 3:36pm
will ask them as well, cheers, just don't want to order the wrong size
jasoo,
Jan 1, 3:49pm
Sounds like a lovely car you have there :)
bigmacca,
Jan 2, 6:35am
trysuspension tech in manukau.he will be able to give you sound advice.
saki,
Jan 3, 2:24pm
The best answer by far considering Chris races and rallys escorts.
