Hiab wont slew
fishy52, Jan 2, 6:13am
i have a 3 ton hiab that i use around the farm it now has no power in the slew and i found the gog at the bottom is slipping on the shaft , how do i remove it or i presume it has a keyway
jmma, Jan 2, 6:32am
Got to be careful with those gogs(o:
pge, Jan 2, 6:52am
pge, Jan 2, 6:56am
First step would be to give the whole area a massive clean with solvent, then you can see if there are any methods by which the cog is fixed to the shaft.
If there are, remove, then use a puller to remove the cog, recleaning as often as necessary, then you will be able to see the locking-method used.
Good luck
gammelvind, Jan 2, 6:57am
Whoa! I hope your gog doesn't attack Israel.
a.woodrow, Jan 2, 8:05am
Lol thats a very clever post for motoring
bashfulbro, Jan 2, 4:48pm
They are Wogs that attack Israel
whqqsh, Jan 2, 5:00pm
unusual that it wont slew then if it has Gog
