Where to buy shorter shocks please?
nutslap, Jan 2, 10:52am
Aside form Repco,where would I find shorter than original shocks!
bitchwitattitud, Jan 2, 1:02pm
Autolign! SAS! George Stocks! Those are susp specialists
1ollie, Jan 2, 1:07pm
You normally have to find ones from another vehicle that are shorter to suit what you want as generally they do not make different lengths.
Repco will normally have what you need its just a matter of finding a staff member that has a clue about there job otherwise your best bet is Autolign or maybe Partsmaster, Central Autoparts, Appco or similar
a.woodrow, Jan 2, 1:59pm
Depending on the type of shock, you can also get them shortened. If you are fitting lowering springs inquire with the supplier, some can supply a shorter shockie to suit
flashgordon_nz, Jan 2, 2:38pm
what sort of vehicle nutslap!
dave653, Jan 3, 7:33am
I found shorter ones for a smaller, same make car.
dave653, Jan 3, 8:32am
Should read. FROM a smaller same make car.
kazbanz, Jan 3, 10:19am
sometimes that can be a BIG problem. The spring rate can be TOTALLY wrong and the damping is just not up to dealing with a bigger /heavier car.
bill-robinson, Jan 3, 10:29am
Oh how true.
twink19, Jan 3, 3:54pm
front or rear, what sort of car
dave653, Jan 4, 12:12pm
Not an issue here. The old girl will out corner the wifes Commodore. Trial and error I spose.
amuso, Jan 4, 12:33pm
Any truck will probably out corner a commode.
