When I stop at a red light or anywhere that I come to a complete halt, my revs drop to around 300 revs and sounds like the car is about to die out, however it hasn't done so yet. When I first got the car around two months ago it s idle was definitely higher than that. Does anyone know what could cause this!
floscey,
Jan 21, 10:37am
some of those old lamborghinis are known to give problems
Jan 21, 10:43am
Yes, Miura and Espada especially. The Countach never had those issues.
phalanax,
Jan 21, 10:48am
Turn the Idle screw up a bit.end of accelerator cable.
jmma,
Jan 21, 10:50am
Can't give correct info without knowing make, model, year etc (o:
_roxxra_,
Jan 21, 11:15am
91 Pulsar x1r two door hatch.
rsr72,
Jan 21, 11:16am
#1- On many cars, check that the idle fuel cut-off microswitch at the throttle body is clicking off the fuel supply when throttle is closed shut. If not shutting off fuel will flood engine at idle causing lower revs and rough idle.
splinter67,
Jan 21, 11:16am
Manual or auto
_roxxra_,
Jan 21, 11:19am
Automatic
_roxxra_,
Jan 22, 2:31pm
Any help at all would be great
zak1998,
Jan 22, 2:54pm
I had this swaped the spark plugs to Bosch Platinum IR Fusion Spark Plugs does not do it now and on offer this week at super cheap autos
luxy,
Jan 23, 5:27am
I had a Daihatsu that did that. All it was was the alternator cut out working,
doug207,
Jan 24, 12:34pm
Take it to a mechanic, they'll probably check for dirty big air leaks and then clean the throttle body and ICV.
