Lsd?
inkapuka, Jan 16, 7:12am
How do you know if ya car has a lsd car in question is a 01 vx commodore v6
jmma, Jan 16, 7:17am
Oopps, Carry on, no drugs in here (o;
intrade, Jan 16, 7:20am
put it in the grass and see if you can get both wheels to spin the same time when you take off . if not then its not lsd
inkapuka, Jan 16, 7:37am
Wel i had it smoking both rear tires up a steep hill not long ago.willthis be standard among the range.!
rob_man, Jan 16, 7:50am
Usually a sticker on the diff head or jack the rear up and turn one wheel. If the other wheel turns the opposite way then it's not LSD, if the same direction it is.
duke250, Jan 16, 8:33am
If you jack up rare of the car and spin one wheel, if the other wheel spins in the same direction it has LSD but if it spins in the other direction it does not.
Source: http://www.youtube.com/watch!v=TI8ewn6HOjg
inkapuka, Jan 16, 10:07am
I cant jack it up only have one siscor jack but i managed to read what the dif head sticker has on it. Hasca barcode with a big FL beside it and then has 9208 5132
S/N 099443
Ratio 3.08:1 then under barcode it has *65 PL U 099443*
DO NOT REMOVE THIS LABEL
rob_man, Jan 16, 10:23am
This is the only reference to that diff I could find with a Google search.
"vl/v8/28 spline/4 pinion/3.08 open wheeler/optioned with LSD/thick axles"
Look under the bonnet and find the driveline code then google it.
inkapuka, Jan 16, 11:03am
Where is the drive line code mate
inkapuka, Jan 16, 11:07am
M30 trans ln3 eng gu4 axleor on the holden plate it says option awx sws sbs lsw
inkapuka, Jan 16, 11:28am
forums.justcommodores.com.au/v-
t-vx-holden-commodore-1997-200-
2/123597-vt-vx-lsd-identificat-
ion-codes.html
inkapuka, Jan 16, 11:30am
My car does not have a lsd
inkapuka, Jan 17, 10:15am
Lol yeh my car not a farm banger lol
