Twin air horns
inkapuka, Jan 23, 7:38pm
https://www.youtube.com/watch!v=rquPHWWYLJc&feature=youtube_gdata_player
Now is it possible to have it wired up like so when you push the horn on steering wheel it turns on air hornsnot the normal horn! so pretty much get rid of old horn and swap it with air horns.
Brought Them from repco
a18a, Jan 23, 8:24pm
yup, disconnect old horns, and wire new horns to where the old horn was. use a relay though, otherwise you'll probably just blow fuses, or they wont be as loud/all you'll hear is the compressor not pumping enough air through the horns.
inkapuka, Jan 23, 9:02pm
Yeah sweet it came with a relay so would i just swap old horn relay and put new one in its place
jmma, Jan 23, 9:08pm
No,use horn wire to relay power, live feed to relay and then wire from relay to compressor. Use diagram that comes with relay. can't remember the numbers off hand (o:
jmma, Jan 23, 9:11pm
a18a, Jan 23, 9:37pm
oh and also keep the relay out of the weather, otherwise you might get woken up at 1am by your horns going off. /experience.
Does your standard horn have 1 or 2 wires going to it!
inkapuka, Jan 24, 2:22am
I think
