5 3/4" sealed beam 3 pin curved glass headlights.
neville48, Jan 9, 7:09pm
I have tried lots to buy these, new and/or second hand and they seem to be rarer than the poverbial rocking horse excrement,Flat glass ones are there but not curved glass, some retailers have recommended trying Oz or England. Any leads in New Zealand semi sealed or sealed, am getting desperate.
mrfxit, Jan 9, 7:28pm
Most early English & a lot of early Japanese cars had that size.
Lucas was the main manufacture
Good selection here of Hella lights
PDF download link .
www.hella.co.nz/Resources/./01)./Headlamps_2010.pdf
gammelvind, Jan 9, 7:31pm
Try Kawerau Panelbeaters, I saw something like that sitting new in boxes covered in dust.
mrfxit, Jan 9, 7:33pm
This guy often has a few things of that age & type
"stagea97"
twink19, Jan 9, 7:49pm
might have some, will look tomorrow,can list them
treachug, Jan 9, 7:50pm
Going by your description thats a common as headlight unit (outer 5731 3pin & inner 5712 2 pin. Find it surprising that you are struggling to find them. We carry them at work (& have stock) - I will check but am positive they are curved. Holden HK, HT, HG, HQ etc Premier/Statesman had the twin units & were sealed type. The later semi sealed were used in Hz models etc & these were flat glass QH type.
bae13, Jan 9, 7:56pm
BNT will do them, The jaylec brand ones are curved. or try 0800 daparts
Most sealed beams are made in india since bosch and stanley stopped making them, the quaility is a bit hit and miss but if your anting seal beams then your not wanting them for night driving lol
xs1100, Jan 10, 5:05am
not exactley the brightest light out there normally only 60/55w
lookoutas, Jan 10, 6:11am
Do you want genuine sealed units!
I know where you can get crystal style semi-seal units that look swish, and take a Halogen bulb.
neville48, Jan 10, 6:34pm
The link does not work, cheers.
neville48, Jan 10, 6:35pm
Please check yur info because if you have some I want them, curved glass!
Tried BNT, all flat glass.
neville48, Jan 10, 6:36pm
Thats OK because I am not the brightest driver haha.
neville48, Jan 10, 6:37pm
These would not look good on a 60's yank tank, cheers tho, may end up that way
trade4us2, Jan 10, 7:04pm
I've got a 7 inch curved headlamp off an XJS.
When I had a '75 XJ6 the small headlamps were $9 and the big ones $14, from my local garage.
neville48, Jan 10, 7:05pm
Not so now.
neville48, Jan 10, 7:10pm
Please "word up" if you do thanks.
treachug, Jan 10, 7:12pm
will check in morning & let you know
richardmayes, Jan 10, 7:14pm
This surprises me because I have never had any problem getting the sealed beam lights you seek from Repco. and I went through about half a dozen over a couple of years before it dawned on me that it wasn't crappy luck and I actually had an overcharging alternator!
("Revolution race gear" branded ones were about $30, although for a while they weren't stocking those and only had a $50 one instead. )
neville48, Jan 10, 7:24pm
mmmm hmmmm, and I have another punter with a thunderbird that wants some too, curved glass like the original stanley type ones !
richardmayes, Jan 10, 7:31pm
Yes, my old Triumph has a mix of original Lucas. Stanley, and Repco lights.
The curve of the glass is the same. The patterns of ribs on the casting of the front glass are completely different of course but you have to get down on your hands and knees to really tell.
What doesn't help is that different people/ outfits seem to use the terms 5 3/4" and 5 1/4" pretty interchangeably to refer to the same lamps!
Also Repco front counter guys and girls vary a lot, from utterly clueless to absolutely excellent, so it pays to take a blown lamp in with you to compare.
treachug, Jan 10, 7:41pm
Agreed - I've been selling car parts for 32 years & also find it amazing the parts people today cannot supply the 'common as mud' unit.
We have the 'Revolution' branded ones in stock so sounds positive
http://www.rarespares.net.au/rsnz/ProductPage.aspx!product=HLA1009 http://www.rarespares.net.au/rsnz/ProductPage.aspx!product=HLA1010
bae13, Jan 10, 7:53pm
did you get the 'jaylec' branded ones, im positive they are curved. try 0800daparts then
neville48, Jan 10, 8:22pm
Yep thanks for that too, Nev.
lookoutas, Jan 11, 6:48am
Just be aware that if they're for a car due to be VIN'd, they might need to match.
