2005 vz commie. Hi alljust bought the wife above caron the display it tells you how many ks to emptydoes this need to be set whe
skippy33,
Jan 25, 5:58pm
hi all,just bought the wife above car,on the display it tells you how many ks to empty,does this need to be set when you put fuel in, doesn't seem very accurate,says 220 to empty,but fuel gauge is on less then 1/4,also when driving it says 220 then goes up to 230 then down to 210, hoping the computer not playing up,cheers for any info
austingtir,
Jan 25, 6:10pm
Thats normal if your coasting down hill using little fuel your km's to empty will increase. If you then accelerate to pass your km's to empty will drop.Its calculated off the the litres used per km or km per litre whatever one holden uses.
Jan 25, 7:02pm
No you don't have to reset anything, the DTE figure floats all over the place, there are complex calculations involved that are changing all the time that involve engine speed and load, how much fuel is left, what your driving style is and has been etc. If you have been driving a lot in urban areas then start doing constant throttle driving on the open road the DTE goes up and vice versa.
a.woodrow,
Jan 25, 7:15pm
The computer takes into account previous usage and updates according to current usage, there are very few circumstances in which you will get it accurate, and it will never go down in km's matching the ones you have driven
panelvanner,
Jan 25, 9:30pm
With a commie, if relied on, chances are you will run out before the ) km shows.
bullfarmer2,
Jan 26, 6:19am
na mine i find is quiet accurate (on open road that is). Another thing you could do to reset it is disconnect your battery and reconnect it, but make sure you have the code for your radio. It will be more accurate then but dont do it too often. Once will be enough. Thats from my experience anyway, other people will disagree
nz2293,
Jan 26, 9:31am
id just watch the guage when its down fill it up
gmphil,
Jan 26, 10:00am
Found all mine even old vn calais to be accurate ,it changes to suit driving .drive nicly for while then fang it u will notice it will change tellin u less k to empty as u usen more gas .if u put in twenty bucks at gas station will tak a bit driving to regester if u fill will compute straight away. Do u have hand book! It explain it all in there.
skippy33,
Jan 26, 3:33pm
well there's an idea,lol
skippy33,
Jan 27, 6:07am
still says 130 ks to empty but display also flashing saying very low on fuel,lol,dont think i will pay much attention to the ks to empty one,lol.
