Lap belt
poohbear011, Feb 6, 3:12pm
dog decided to chew the rear lap belt in my car, will any lap belt fit! last 1 i got was from a sentra for my sentra but can get 1 local from a subaru
cheers
saxman99, Feb 6, 3:22pm
No you can't.The VIRM states that if you change a belt to other than the manufacturers spec then you need approval from the manufacturer to do so; they are very unlikely to provide this.
unbeatabull, Feb 6, 3:25pm
How do aftermarket seatbelt companies get away with it then Saxman!
If it fits, looks the part and looks like it is how it is supposed to be, (no massive excess, facing hte wrong way etc) then I doubt the inspector will even notice it.
saxman99, Feb 6, 3:27pm
Don't know. I wondered that too, but the virm appears to be clear, unless I'm reading it wrong.Perhaps it's accepted that seatbelts are "all created equal " and so if fitted correctly to original mounts then they automatically meet the specs.
jokerboss, Feb 6, 3:28pm
poohbear011, Feb 6, 3:28pm
how would anyone know what brand its from! last 1 was a different colour,(grey) compared to the charcoal the rest are and it was ok, the wof inspector just checked it was frayed/damaged like the old 1
unbeatabull, Feb 6, 3:33pm
They have tags or a stamp on them, usually by where they bolt into on the car. A lot of cars though it would be a bit of work to actually find it, removing trim/seat bases/upholstery etc to find it. As long as it secures fine, isn't fraying, discoloured or damaged etc, I don't have a problem with it.
the_chooky, Feb 6, 3:45pm
Leave a penthouse on the back seat when you go for a wof.
meathead_timaru, Feb 6, 3:50pm
You're misreading the VIRM. What is stated is about modifying a belt assembly, not simply replacing a belt assembly with a different but complete, as-manufactured assembly.
poohbear011, Feb 6, 3:54pm
ok ill search the wreckers tomorrow for a nissan 1 to save myself the hassle
saxman99, Feb 6, 3:55pm
Ok cool.
andy61, Feb 6, 3:56pm
The Subaru belt will be fine.
bjmh, Feb 6, 3:58pm
ha ha you should never judge others by your own actions.
cowlover, Feb 6, 9:23pm
I had a crazy problem once.WOF man insisted that i had to have a center lap belt ina car that had never had one.Went home, took belt from our other car, bolted it in with existing bolts and passed.Went home and took it out and was never asked again in the next 10 years.Who knows what planet WOF man was on that day.
