from key and inside!barrel dosent work, and when i pull cable that dosent work either, may have to replace cable and catch
llortmt,
Feb 13, 7:51pm
Yes it must open, one way or another and latch securely.
nuberanda,
Feb 13, 7:58pm
you can get away with it, i did and mine doesn't work.
llortmt,
Feb 13, 8:01pm
No YOU got away with it, that doesn't guarantee such 'success' for others.LOL As I said it must open and latch securely.
saxman99,
Feb 13, 8:18pm
Is the AVI also meant to check for corrosion around the hinges & frame etc!
I guess it needs to open for that if so.
My WoF guy has always checked the latch operation.
dasfi,
Feb 13, 8:18pm
it opens through the back seat if you manually move the leaver lol
llortmt,
Feb 13, 9:15pm
& that's why it needs to open & latch securely not to mention inspection of seat belt mountings if visible and possibly the security of the spare wheel.
pollymay,
Feb 13, 11:41pm
Yes it needs to work, can't check the spare wheel and areas around the rear for damage or rust without opening it. So if they "don't notice" it's cause they're doing a crap job of inspecting
smac,
Feb 14, 6:16am
llortmt, and you an inspector! If so, please explain why a spare tyre in an enclosed boot needs to be secure!
