I rejected a vehicle for an SRS light that stays on all the time,owners mate "fixed it" light now doesn't go at all.i rejected it again.Owner took it to Auckland and got a wof .still not fixed.now he has asked me for the $52 back ,that i charged him for my inspection.I have said politely that won't be happening.
fiatracer,
Mar 11, 12:14pm
you did your job. You got paid. end of.
johnf_456,
Mar 11, 12:22pm
You are well within your rights, some don't realize its xyz for the inspection fee regardless of a pass or fail.
nightboss,
Mar 11, 12:30pm
You did your duty.
If he returns direct him to disputes, tell him your time will be charged at $250 per hour or part thereof in your counterclaim.
a18a,
Mar 11, 12:42pm
the least they could've done was wire it to the battery light or check engine light instead of just removing the bulb. geez
a.woodrow,
Mar 11, 5:22pm
Ring the outfit who inspected and passed it and asked why they though it was ok that the light didn't come on!
incar.,
Mar 11, 5:26pm
report it to the Ltsa, oh wait i have inspected hundreds of unsafe vehicle's with new wof,spoken to ltsa and was told i was the first to report any such happenings, gave up
steve98h,
Mar 11, 6:18pm
i failed a car laster year for a front left shock that was leaking so bad that it was spraying oil all over the inner gaurd and a broken engine mount. The owner drove straight from my workshop and got a electronic shock absorber test and passsed! then striaht to vtnz and passed a woff all on same day then came back and had a go at me. shock was so F**ked i could lift the shock through most of its travel with my hands and yet passed a electronic shock absorber test! hmmm
llortmt,
Mar 11, 6:32pm
You have a complaints procedure that you must carefully follow and document in your prs manual, you should respond in writing, if they're not happy (and they wont be) direct them to the NZTA 0800 number so they may appeal.
Mar 11, 6:36pm
yea greg murthy knows mta . wof is so important .to scam money
snoopy221,
Mar 12, 1:00am
Jesus H far King Christ End of the day it is your name being signed and if you do not wish to sign YOU ARE THE INSPECTOR SIGNING
Simple as FAIL-Comments written name signed as FAILURE.
mrfxit,
Mar 12, 6:15am
Check process is . Key on = srs light on Start engine = srs light goes out a few seconds later = PASS If neither of the above happens in that sequence then = FAIL
Well done. Customer can go whistle all they like but it's only going to cost them $$$ plus their current wof Now go & report the 'other' garage to be noted for a bogus wof
mrfxit,
Mar 12, 6:17am
Mates rates test
Mar 12, 6:59am
I think in this case dissin VTNZ is silly-I betcha a thousand bucks that the shock was all shiney and clean looking when it went to VTNZ.
bigfatmat1,
Mar 12, 3:39pm
this is incorrect light can go out before engine is started
trader_84,
Mar 12, 4:00pm
Now that you've asked - I reckon you're too 'picky'
mrfxit,
Mar 12, 4:08pm
True but how many ppl wait that long after turning the key, to starting the engine
bigfatmat1,
Mar 12, 4:32pm
alot
