Rough starting?
inkapuka, Mar 1, 2:39am
Sometimes my v6 commodore starts real rough and only just sometimes. Thought. It was the alternater but it's charging fine what could it be! Its 2001 with 132kms
m16d, Mar 1, 4:38am
Run it on 96, it'll start fine.
treachug, Mar 1, 5:13am
Could be inlet manifold gaskets.the ecotec V6 (VS-VY) is not as prone to leaking manifold gaskets as the earlier V6's (VN-VR) but still known to do it.
inkapuka, Mar 1, 6:23am
Its 95 egg and are the gaskets expensive to replace i was wondering maybe the spark plugs could be replaced
budgel, Mar 1, 2:58pm
It wouldnt hurt.
franc123, Mar 1, 3:13pm
If its been using coolant you would have to suspect manifold gaskets, a brief rough idle after startup is what they do when they leak. Otherwise yes check and replace plugs and leads if no good, bad connections under the coils can occur too.I've also seen VT VX Commies with blocked injectors caused by bad corrosion of the fuel rail, it'd also be wise to pull the fuel filter off and see how restricted it is, if you can't blow through it easily in the normal direction of flow it needs replacing. Although with most of these issues there will be other problems apart from hard starting.
crudeawakening, Mar 1, 3:34pm
if its purly a start (turn over) thing - lots of commodores had the main supply to the starter motor come loose and it begines to burn. check that if it makes sense
inkapuka, Mar 1, 7:29pm
Yes it has been using a wee bit of liquid in the radiator and its quite black and sh1t looking above the rocker cover. I think thats what it is called looks like it's leaking oil around there and its burning a wee bit of oil it only got serviced a few thousand kms ago
inkapuka, Mar 1, 7:40pm
Not very good pic but its kinda noticeable black quite bad
monsieurl, Mar 1, 7:55pm
Probably a sensor, vacum hose, plugs or points. I don't know if Holdens have Control valves but that could be something too!
outbidyou2, Mar 1, 9:19pm
rough starting! She can be a little in the mornings but warms up quickly with a gentle nudge.
inkapuka, Mar 2, 5:00am
Its hard to explain
