Motorbiking cornering tips
msj23, Mar 15, 7:14pm
We have all been in this situation - going into a corner and your going too fast
What do you do to stay safe! Anyone got any tips. Brake! No brake! lean into the corner and throttle! drop throttle and lean!
superfreek, Mar 15, 7:16pm
By the time you get into the corner it's too late - your best to just lean hard, counter steer, look through the corner and pray to god you make it.
During Mid turn, unless you are skilful, the brakes generally will make you bin it.
Best measure is to slow down before the corner and know your and your bike's limits.
gunhand, Mar 15, 7:16pm
Hope the ambos know what there doing. But more than likely (unless your in a big city) odds are they may not.
msj23, Mar 15, 7:20pm
God its a scary feeling. Anyone who has been in this situation knows about that "oh sh*t" moment that occurs when you realize you may well be eating gravel or worse
gunhand, Mar 15, 7:23pm
But seriously there are ways to help yourself out but each situataion is different (you would hope) so each one may need a differing approach to the problem but unless you have the reactions of GP rider its proabably all over rover. Just hope ya cell phone dosn't get broken and someone isn't recording it and it ends up on YouTube. And of course you wern't wearing ya jandels that day.
oliver6, Mar 15, 7:33pm
Push the inside handlebar gently away from you and continue or increase acceleration. It is countersteering. Try it the next time you ride, even on a straight road.
desmodave, Mar 15, 7:36pm
Get your eyes tested is a good place to start. Most bikes can out perform their rider.
patiki1, Mar 15, 7:39pm
newtec1, Mar 15, 7:43pm
You will see that at the springs next W/E.They don't have any problems with it,and they don't have brakes.
bitsy_boffin, Mar 15, 7:44pm
Get brave and push on that bar to increase the lean.Look where you want to go.These two things are more important than any braking or throttle, if you look at the obstacle, you'll hit it (target fixation), and if you don't lean, you're not going around the corner.
For the average rider, the bike will have more grip and can give more lean than you give it credit for, and by that time, you've nothing to lose anyway.
A low side slide from leaning too far is far preferable to slamming into a wall or high siding over the top of it.
wellystretch, Mar 15, 7:53pm
True that, with a bit of practice you can use a wee bit of back brakes mid-lean though
ezekiel67, Mar 15, 8:16pm
Watch this:
http://www.veoh.com/watch/v20959402FsQ2jz6A!h1=A+Twist+of+the+Wrist+2
A twist of the wrist by Keith Cole - helps explain a lot.
outbidyou2, Mar 15, 8:17pm
good advice there ms
oliver6, Mar 15, 8:20pm
Brake before the corner and accelerate through it. You can apply a bit of rear brake at the same time as accelerating, but for road riding you shouldn't have to.
bigfatmat1, Mar 15, 8:28pm
Stay in your lane.
cassina1, Mar 15, 8:46pm
I have tapped the brakes about 25% into the turn which has enabled me to increase lean angle untill mid turn then I power out. In the wet though I would never tap the brakes into a turn but always enter at the recomended speed limit or lower anyway.
budgel, Mar 15, 9:14pm
Is this what you were thinking of!
http://www.pneus7.it/images/Ruben%20Xaus%20Mores.JPG
outbidyou2, Mar 15, 9:23pm
Watch for cars. Stay 1.5
wrong2, Mar 16, 4:01am
learning to push the front to scrub off speed is far easier to learn on a dirtbike
muzz67, Mar 16, 6:27am
Agreed! Learn a few dirt skills before goin road riding. Then running off the end of Powerbuilts front straight aint so scary!
kazbanz, Mar 16, 6:47am
I had a whole screed of advice for you about brakes,about road positioning about rider training ,leaning etc and deleted the whole lot.
What I would do is brake to scrub off as much speed as I can then I'd tip into the corner looking NOT for that "inevitable" slide in the gravel but to where I want to go.
Most road riders genuinely don't know just how far they can crank a bike over. Its a truck load further than you would ever believe
clark20, Mar 16, 8:29am
When that happened to me, I straightened the bike up, slowed down as much as I could , made it to the grass (so less damage when I and the bike came off) and as I was sliding towards the white road marker (wood back then) I wondered how well they are placed in the ground. (not much thankfully). I still have the white mark on the jacket to remind me to be more careful.
meathead_timaru, Mar 16, 10:11am
Go faster and faster around the corner until you fall off, then go a little bit slower than that.
NZTools, Mar 16, 10:30am
Haha. Love it.
msj23, Mar 16, 10:47am
Thanks kazbanz, good practical advice as always.
