DriRider jacket leaking?
singing1, Mar 18, 2:17pm
Have a jacket that doesn't keep the water out.are you supposed totreat them with something to keep the water out! I find it a great jacket otherwise.
redhead96, Mar 18, 2:35pm
Scotch guard have a product you spray on your clothes to make water proof.
kwaka5, Mar 18, 4:07pm
Alot of textile jackets do leak. I have a tenkic and it's a great riding jacket but leaks like the proverbial sink. I have a jacket to put on over the top. That keeps the water out nicely. Just a pain to pull on and off. Some of the newer jackets are compleatly waterproof but you pays for whats you gets
singing1, Mar 18, 4:07pm
Bloody things petty new too. I wonder how that spray on stuff would effect the breathable outer material!
peril787b1, Mar 18, 4:19pm
If it's near new, why don;t you contact the shop you purchased it from to see if it's covered under warranty! In a lot of cases, the lack of waterproofness could be cos it needs cleaning. I'd suggest not to use scotchgard or an of the other spray on products UNLESS they're approved by DriRider, it might damage the waterproofing, and void any warranty.
trogedon, Mar 18, 4:46pm
I have a Spidi jacket that leaks.eventually. It would seem to be the last thing to worry about this year!
There is a bees wax product that can be rubbed into the seams. I did that to my leather jacket and it helped keep it dry.
oliver6, Mar 18, 5:14pm
I haveseveral jackets, Dririder, Teknic, Spidi , Leatt,and a couple of other brands. The Dririder is the most waterproof. They are all waterproof from new, ( except Spidi) and then usually deteriorate as they get older and dirtier. They are so cheap now it is easier to buy a new one every 3 years than to buy the correct waterproofing and was and treat them.
mantagsi, Mar 18, 6:34pm
Get it washed WELL and dried, be gentle with it and that should stop the leaks. The dirtier they are the worse they leak. Just a bit of a pain in the arse to dry them nicely. Dry it gently too, as it is a nuisance if you displace the armour pads.
Good luck :) Oh, and if you have a set of dririder gloves or are thinking about purchasing some, they are just about impossible to dry, have tried drip drying, tumble drying, microwave, hot air tubes, whatever. It doesn't work! Best option seems to be to go back to non waterproof gloves and just get over wet hands
oliver6, Mar 18, 6:40pm
Lightweight, waterproof overmitts
danchop, Mar 19, 7:33am
they have a waterproof membrane in them,so this has failed,cleaning,spraying on stuff wont fix it
bounce16, Mar 19, 7:42am
When washing them make sure you get a product specific for washing these jackets.Can be bought from bike shops that sell the gear.
singing1, Mar 19, 10:13am
Under very close scrutiny the stitching on the inner lining has come away in the arm pit. This is the rain barrier between the outer Cordura and the inner winter lining. It was the area where the water first started to leak through the jacket so I will get that sorted.
kamitchell, Mar 19, 10:24am
I used to use a product called Dubbin years ago on my wax cottons, used to keep them dry.
offrd1, Mar 19, 2:19pm
My pants leak like a sink as well.scotch guard was hopeless
mbikeman1, Mar 19, 2:45pm
i use a washing liquid that i got for the bikeshop.They come in sachets and cost me about $3 or $4 each works great on both my Cordura jackets and my pants.
guest, Sep 26, 6:06am
I know exactly what you mean! I LOVE fall becusae I can start piling on all sorts of crazy combinations of clothing and right now my closet is desperately begging for a cute jacket a leather one, to be precise! Haven't found one yet, either, though! -giedre
guest, Sep 27, 3:34am
Agreed! I want one with the 3/4 sleeves like this and they eiehtr fit bulky or awkward. Jackets can be harder to fit than jeans sometimes! I wish I could put on a leather jacket. Still 85 degrees here.
guest, Sep 29, 1:05am
Simile / ye amr naam er meaning o kintu Upoma!!!! jai e hok!!!!! riveew ta atoi shundor hoise mone hocche akhony chute jai movie ta dekhte!!!! r riveew er majeh majhe j pic gula disen oigula riveew ta k r o akorshoniyo kore tulse!!! r ai model moin k to ami age kokhono dekhini!!! chele ta to dekhte khub e shundor!!!!!!!
