Cig lighter stopped working URGENT not for smokin
eldub101, Mar 29, 2:11pm
i need it to work for my RT in the car please helpi cant read chinese or what ever language it is in the fusesanddont know what the hell im doinghelp
cjohnw, Mar 29, 2:17pm
You will probably need to remove them one by one and inspect them till you find the blown fuse. Process of elimination unfortunately.
eldub101, Mar 29, 2:18pm
yeah but there so manyandall diff numbers guessing the rating or somethingand they are tiny little things compared to last car
cjohnw, Mar 29, 2:21pm
There will probably a small plastic tool in the fuse box that can be used like pliers to remove and replace them.
flashgordon_nz, Mar 29, 2:43pm
what sort of car are you talking eldub101!
granada, Mar 29, 9:21pm
Just start at one end and work your way through them , Murphys law states it will be the last one you test
strobo, Mar 30, 5:54am
Some are designatedpower supply sockets and others are the commonelement ciggie type .Check at the back of the socketit self as there is likely a small grain sizedfusible link that can"open circuit". leaving the main fuse un blown. You can either bypass this link fuseas the main fuse is in place anyway at the main fuse board or simply buy another socket of the power supply type.
