Head lamp - dash board
pandana, Mar 31, 8:46pm
normally when i turn my head lights on, the high beam indicator light only comes on in high beam. but lately its stays lit even when the head lights are dipped - what causes this!(guessing ill need to resolve it before the wof!)
jmma, Mar 31, 9:00pm
Make, model of vehicle(o:
franc123, Mar 31, 9:09pm
Thats a weird one! If the high beam lights are killed the dash light should be too. You're certain its high beam warning and not a foglamp one! You would have to suspect a dipswitch problem first.
edangus, Mar 31, 9:16pm
Had it once on a Mazda 323 - it was the stalk, worn I guess. Swapped it out, no more problem.
pandana, Mar 31, 9:26pm
its a 2006 nissan wingroad.all the fuses are good - all the dash lights work. every thing works as normal - except the high beam indicator light staying on. so would that possibly be the switch in the stalk then>!
edangus, Mar 31, 9:53pm
Could very well be. Try holding it in place etc. Worth a crack to eliminate it, other than that - Sparky Time
owene, Mar 31, 10:02pm
Probably a cracked pentambulator block which is allowing currants to leak through the contacts back into the bulb circuits.
icemans1, Mar 31, 11:19pm
black currants!
daryl14, Apr 1, 3:51am
Nooo, Blue light - Blue currants.
owene, Apr 1, 4:50am
icemansd1 why are you confusing the issue, they are blew.
sred69, Apr 1, 6:00am
Probably a headlight bulb gone, had this a few times on nissans, Bulb blows and main beam warning light stays on, or the connector to the bulbs has burnt out/poor connection
pandana, Apr 1, 7:07am
the prize goes to "sred69"yep one of the headlights was out. but why was the bit that got scary. jiggled the plug and it worked. took the plug off to clean the contacts and discovered one whole side of it was !melted! ( resulting in corrosion on the contact) what on earth would have caused it to get that hot - note no headlamp fuses blown!
mugenb20b, Apr 1, 7:11am
It's a Nissan thing.
edangus, Apr 1, 8:23am
Wow, I knew Nissan had electrical issues but jeez that's a worry. Glad its sorted.
therafter1, Apr 1, 9:36am
Lol . I've never worked that one out Mugen, for some reason Nissans melt the little devils on a regular basis, but you only see it on the odd occasion on other vehicles. I imagine Bigfatmat or someone will know the answer.
bigfatmat1, Apr 1, 9:51am
loose and or dirty connection gets hot melts common problem various makes and models
