we have a 928. the car will not start. its like the battery is flat but the car has new battery, it also has new leads. the car will not tiurn over its like it has a flat battery but it doesnt.
Feb 8, 5:28pm
Check your earth cables that go from the battery to the body and engine to body and positive cable that goes to the starter.
headcat,
Feb 8, 6:37pm
Cam belt? Head gasket (water in cylinder)? All sorts of reasons given the available information.
moparpete,
Feb 8, 6:47pm
As above, but also check if you have power to solenoid and also relay. When you say it won`t start at all, when you turn the key do you here any noise at all like a clicking sound?
quickbuck,
Feb 8, 7:01pm
Yup, for a car of that era, i would be checking where all the electrons are supposed to flow. Pull apart all the cables and clean up the contact surfaces. There is a CRC Product that cab be good for that (CO Contact Cleaner), but some good ol Scotch Brite with 556 can do a good job of it too.
nzdoug,
Feb 8, 7:05pm
Got other electrics ???????
Feb 8, 7:14pm
1) starter motor was the problem all along. 2) you zapped something and have blown fuze/fuzeable link
Feb 8, 7:21pm
Check that the motor actually turns over by hand first, otherwise suspect a starter issue.
hunter__,
Feb 8, 7:55pm
Get someone to turn the key, while someone else taps the starter motor with a copper hammer or similar (out of gear obviously) the tapping can be just enough for the solenoid to get moving and bridge the main contacts, my 911 used to need that treatment until I got a new sm. If it starts, its time for a new starter motor. Cheers
trogedon,
Feb 8, 8:10pm
Its SPELLING help you need - Porsche.
andrewph,
Feb 8, 8:19pm
If its an auto check the position of the gear lever and give it a wriggle while trying to start it. Does it have an alarm system? Check if it has power down at the starter while the a helper cranks it. Take it from there.
Jun 30, 3:17am
i would remove the sparkplugs and see if it turns over
