People who are familiar with MSNZ requirements, I know I should ring them but is 9pm. when making a footing plate that covers a vertical section too, do I have to make the overall plate area larger so that the horizontal section is 120cm^2?
A box is another way which Ill consider too. What are your thoughts on this? Please only if you have experience in this department!
unclejake,
Jul 1, 8:17pm
Did you check the PDFs? They used to be online when I was racing, but if the exact subject isn't covered you'll just have to wait to phone Julian (or whomever it is now) tomorrow.
mgmad,
Jul 1, 9:14pm
No the requirement is just for total area not in any particular plane.
Obviously if you count the vertical in the 120 SQs you will still have to add a bit to the floor section to weld your roll bar to, I used 120sqcm as the minimum.
morrisman1,
Mar 25, 4:18am
I got the official word from MSNZ, they said its not well worded. The min area is 120cm^2, and part of that area must be on the horizontal plane. It cannot all be on the side of a sill panel for example.
