Snorkel need cert?
bloodthirsty, Apr 13, 5:37pm
Do you need to get certification for putting a snorkel on your 4x4?
aj.2., Apr 13, 5:41pm
no,
franc123, Apr 13, 5:43pm
Generally no, if there are no structural mods involved. If you were removing material from close to a cab mount in order to fit the pipework it may require it, but factory made kits are designed to avoid that sort of problem.
m16d, Apr 13, 6:03pm
saw one on an old landcruiser in Perth only last week. made entirely out of marley down pipe and fittings.
looked pretty cool too.
bloodthirsty, Apr 13, 6:44pm
Cheers team, think I'll pass on the down pipe trick.
brokebloke1, Apr 13, 6:53pm
years back we had a Toyota surf put a snorkel on it and never got it cert , only once did the WOF man question the snorkel , wanted to know who put it in went over it with a "fine tooth comb" failed it as he could see raw steel around the inside of the snorkel ! painted it and it passed.
pico42, Apr 13, 7:01pm
There are more than a few like that in NZ as well.
bjmh, Apr 14, 5:29am
bjmh, Apr 14, 5:33am
you'll be able to do this with a snorkel. tui moment.
floscey, Apr 14, 5:52am
just keep it on the glovebox untill it gets to deep.
sr2, Apr 14, 7:22am
Brilliant; bloody mad Aussie!
As soon as the front of the truck sank deep enough he got some traction from his front wheels.
bjmh, Apr 14, 7:28am
you didn't know Toyota made boats ha ha
briantamaki-god, Apr 14, 10:45am
i went up to swing bridge at lake sumner the landrover had a v6 in it when he crossed the river it sounded exactly like a jet boat
emmerson1, Mar 12, 5:43pm
I read that you're meant to open the doors if you start to get floaty. Anyhow, I would just like to say, nope. nope. nope.
When I was young, I drove my little FWD mitsi mirage through a deep ford, slightly more than knee deep. Just about stalled it, but got through. On the other side the engine was making a slight ticking sound. Three months later, the mechanic tells me that the ticking was one of the con-rods lightly brushing the side of the engine case it was so bent.
