40mm x 50mm x 2.5mm RHS mild steel
nightboss, Jul 30, 5:12pm
I have a need for 2.2m of this hard to find RHS size. None of the NZ steel suppliers stock this size as far as I can find.
It is to make two spare parts the same as the ones in use, the parts in use were fabricated in England when the plant was new.
Anyone know if they have any ends on the steel rack in the shed, workshop,
or hidden away that could help me out.
Of course I would expect any exchange to include a cut for TradeMe (in the form of a listing) so they get appropriate credit for facilitating this.
40wav, Jul 30, 5:38pm
I have a reliable contact. I will ask. Not around the home email machine much, so give me a couple of days.
Can it be heavier walled or must it be 2.5mm?
nightboss, Jul 30, 6:17pm
Heavier is fine, the important size is 40mm x 50mm. Thanks.
40wav, Jul 30, 6:33pm
Cool. Just to clarify, is that OD or ID?
nightboss, Jul 30, 6:38pm
Outside Dimensions.
Kind sir.
alfred011, Jul 30, 9:05pm
you could make a piece by cutting 10 mm out of a piece of 50 x 50 and welding it back together the stuff you have could be an imperial size if made in England.
nightboss, Jul 31, 3:50am
Possible, but a big task to keep straight on pieces 650mm long.
(That is 65cm for all you "dressmakers" lol)
robbo36, Jul 31, 4:02am
Or 25" for old schoolers
kazbanz, Jul 31, 6:04am
Nightboss. I haven't seen 2'x1-3/4x1/8 or 50x40x3 for many years
I think you will need to bite the bullet and buy 50x50 and have one edge machined down.
What size is critical ID or OD. If its ID maybe a couple of packers
biddy6, Jul 31, 6:08am
You could use 40x40 and tack a piece of 40x10 along one side.
40wav, Jul 31, 6:27pm
Hi nightboss. Had an ask around and it seems that size is just not available. It would have been 1 and 3/4" by 2"
Suggestions were pretty much as above. Use 40mm x 40mm and weld either a 40mm x 10mm strip on one side or 40mm x 5mm strips on two sides. Personally I would go for the two strips as it would be much easier to control distortion. (Drill holes in the strips and weld through those onto the 40mm). I'm sure your local engineering firm could make this for you.
I could make it but the postage would kill it.
Good luck mate.
nightboss, Dec 7, 1:35pm
Will make it myself, I have the gear at work,
good call on the 40x40 + 2x 40x5
