Help with spline?
sr2, Jul 21, 4:15pm
Hi guys; I??
michelle322, Jul 21, 4:27pm
the easiest way would be get the triumph spline machined into a bush that can be fitted to the model T and retained by a keyway or scotch keyed
sr2, Jul 21, 5:15pm
The diameters are very close (amazingly so considering the 60 plus years gap in manufacturing), I'd need to fabricate a stepped adaptor and would still need a 3/4" by 48 broach to make the internal spline.
m16d, Jul 21, 5:17pm
OK. I'll ask. WTF. ?
michelle322, Jul 21, 6:07pm
you use the triumph steering wheel as it already has the spline and make that into a stepped bush or sleeve to fit the T.
poppy62, Jul 21, 6:15pm
Agree with Michelle322 turn the T2000 steering boss in to a bush and shrink fit it into the ModelT wheel and grub screw it for extra security. Only require a lathe.
sr2, Jul 21, 7:45pm
Thanks for the feedback guys but sadly the diameters are far to close for a stepped bush or sleeve to work; (unless I have access to a broach with the appropriate spline, - hence my original post).
michelle322, Jul 21, 8:38pm
yea,the T steering boss is quite small.How about turning the 2000 steering shaft splines down to a neat fit in the T hole and get a keyway cut in the side of the shaft to suit the original one in the T. have it machined a little shorter and use the 2000 nut to hold it together.
sr2, Jul 21, 9:07pm
Thanks for the interest mate, almost enough meat there to do it (The T uses a square section key) but the obvious solution is to find someone with a 3/4" by 48 broach. Apparently it's a very common size in steering linkages.
sr2, Jul 21, 9:10pm
LOL, it's such a long story about one car over 40 plus years, I probably need to start a blog about the project!
bill-robinson, Jul 22, 10:59am
have you considered changing the column to suit the wheel
sr2, Jul 22, 1:09pm
That could be a possibility but a new column would still need the same sized spline at the bottom to fit the universal joint. (The triumph column has the same sized spline at both ends).
bill-robinson, Jul 23, 5:47am
external splines are easier to make than internal
goose16, Jul 23, 2:32pm
Southwards in Paraparaumu have an engineering shop attached to the museum. Perhaps they could help.
Ken Douglas (Automotion) in Levin does a bit of spline work.
lookoutas, Jul 23, 4:47pm
Is it tapered as well.
Just curios - Haven't got an answer other than some of those Kiwi ones already mentioned.
Back when we could - probably would make a sleeve to fit the Trump shaft on one end, and the T shaft on the other.
Method of joining could have been a shrink fit, or grub screws.
Would still be working today too.
Edit; When I mentioned sleeve - that would probably be a full length shaft with a short piece of the originals in each end.
bbboo, Jul 28, 6:39pm
Try PG hydraulics in Andromeda cres East Tamaki Auckland I have had spline work done here before
sr2, Dec 14, 5:33am
Thanks for all the suggestions guys. I??
