hi I have a factory vl v8 sw and I have taken the quadrajet off and replaced it with another quadrajet off a 350 chev it runs but was wonding because its off a bigger engine will it cause it to burn any thing out or damage my engine cheers
Just go by the exhaust colour you will probably notice lighter colour if it is running lean and maybe could run a bit hotter, running lean is not so good for the motor, running rich wont do any harm.
tony9,
Jun 22, 1:47pm
Depends on several variables, but it does seem to be not uncommon.
Note, I did not say it would run lean, but of the likely outcomes, lean would be the one to cause damage to the engine.
esky-tastic,
Jun 22, 2:18pm
Go to a tune up place and get them to test it with an exhaust gas analyser.
patiki1,
Jun 22, 5:14pm
As above,get it tuned.Good luck finding someone.
sr2,
May 13, 4:15am
On todays unleaded gas?
