Not really motoring but it does have a petrol motor ! I am going to refill the pump with new oil , the spec sheet just helpfully says ''do not overfill'', but doesn't give a quantity, nor does it have a dipstick or sightglass ! Is there a rule of thumb for filling these puppies up?
shiny,
Mar 25, 6:36pm
Is the filler at a low level so that is the determiner?
morrisjvan,
Mar 25, 7:40pm
nope, you fill it through the breather cap which is at the very top.
o0_hamburger_0o,
Mar 25, 7:43pm
a google of model number would provide ample of information. any label to indicate make or model of water blaster?
howz_that,
Mar 25, 7:47pm
If it hasn't been leaking then measure how much comes out and then replace with same amount
morrisjvan,
Mar 25, 8:23pm
I've tried google ,but no luck. It is of course Chinese, so it will have a dozen different names.
morrisjvan,
Mar 25, 8:27pm
Unfortunately, a piece broke and I think the oil level went up! (water ?) so I had to make a new componant and i think I have fixed it , and now wish to fill it back up, to see if I have been successful or not.
doriandarby,
Mar 26, 5:08am
Given that the manufacturer probably copied the design from a known brand, why not google a range of models from other makers and take an average of what they require?
supernova2,
Mar 26, 7:34am
A pic of the pump might help. Its probably a knock off copy of something decent and somebody might recognise it.
frooge,
Mar 26, 7:37am
Usually tilt the machine back on it's handles until the pump housing is vertical, then fill so oil just reaches filler/breather hole. They don't take much. This is the procedure on my chinese petrol powered blaster. Instructions for this were hard to find on a separate small sheet.
frooge,
Mar 26, 7:42am
Tilted forward once (I forgot) to fill and had oil spewing out when running. I thought it was really low!
morrisjvan,
Apr 13, 3:03am
that will be a good starting point.
