Threw a rod
morrisman1, Mar 14, 7:48pm
purple666, Mar 14, 8:00pm
That would make the absolute coolest addition to any Mancave.
tintop, Mar 14, 8:05pm
What is it from - 2 stroke marine engine ?
Looks like a crosshead on the left.
poppy62, Mar 14, 8:07pm
ShIp!?
tintop, Mar 14, 8:10pm
Snap!
nzjay, Mar 14, 8:34pm
Somehow got water in the cylinder? Compressed air start?
tintop, Mar 14, 8:52pm
Crank journal seize I think.
Water in a cylinder would result in only a simple compression load on the con rod and the piston rod - no bending load.
nzjay, Mar 14, 9:04pm
I've seen the result in a big Merrilees ex submarine engine where half a cupful of water was blown in on the compressed air when starting. The inertia in the many tonne flywheel most certainly bent the conrod!
But, yes, you are probably right, that's a rotational bend, not a compression bend
tintop, Apr 30, 5:47pm
:) Many many years ago I saw the rod from a Mirrlees at the Lautoka power station after an oil supply failure. :) Engine alarm went off, operator shut the engine down, but did not isolate the alternator. which then motored on .
Those engines must be bad news! lol
