Snow chains
kauruhill, Feb 13, 3:56pm
Is a set on here I'm looking at that fit a 265 70 16. I drive a navara st that is a 255 70 16. Would they be ok to use or a waste of time
nightboss, Feb 13, 4:03pm
Snow chains work best when fitted to the size wheel & tyre that came standard on the vehicle.
Fitting larger wheel &/or tyres can reduce the clearance between them and bodywork or suspension.
Whether the extra 10mm chain over tyre would be a too loose fit I am unsure, but worth a phone call to a tyre place in an area like Queenstown to discuss your question. (Or to confirm any further advice here).
serf407, Feb 14, 7:54am
It depends on how adjustable the tyre chains are. Depending on tyre tread wear; the larger tyre has a calculated circumference 40 or so mm larger.
It also depends on what condition/ age/ wear the chains have.
Look up snow chain adjusters.
http://www.snowsweat.co.nz/ etc
tamarillo, Feb 14, 12:10pm
Don't chains say what figment they are for? Or is there no box left?
kauruhill, Feb 14, 6:37pm
Yeah they are for 265 70 16 but was wondering if they would work on 255 70 16
scuba, Feb 14, 7:10pm
ask the seller- should say what sizes they fit on the container or ask what size chain they are and look up a fitment chart
skin1235, Feb 14, 7:15pm
yes they will, you'll probably find they will be in the first loop on the back hook and the second on the front - make sure you clip the excess chain on the back hook in or it will damage the underguards
skin1235, Jun 18, 10:15pm
snow chains are very forgiving in fitment, they'll accommodate quite a large difference in tyre sizes before you have to upsize the chains
