Small sand blasters.
grangies, Nov 17, 4:25pm
And before any know it all's rabbit on about auction promotion, etc etc.
I simply want to know about the product before I spend my hard earned money LOLOL.
panicky, Nov 17, 4:33pm
Can you supply the air required?
grangies, Nov 17, 4:47pm
Possibly. I have a 3cyl 16cfm compressor.
What I will require it to be used for, wont be continuous blasting.
I need something for spot blasting painted concrete.
gammelvind, Nov 17, 4:50pm
Looks interesting, haven't sold anything quite like that one, the only comment is the nozzle is the type that needs to be up against a flat surface for the vacuum to work which would make it as messy as a conventional blaster when cleaning up odd shaped items, apart from that looks like a very useful machine.
skin1235, Oct 10, 7:05pm
as you say a useful machine, they use a circle brush around the nozzle gammelvind, catches most of the abrasive and the debris, it is certainly not essential to be on a flat surface - they are very good on flat surfaces, like any sandblasting equipment they are quite hungry on the medium when doing pipes and open type product, ie chairs, tables, engines, trailer frames etc
for spot blasting concrete they would be up there with the top models, the limiting would be grade of abrasive and application rate of it, their ability to recycle on the fly would be a decider to the affirmative
