have used cobbsport acessport v2 to tune my ms3 and i usually put caltex in prior to tune as of yesterday. what is best preforming cant get 98 down south but if i am ever up north can re map it to run on a 98 tune while i am away etc
tamarillo,
Feb 12, 7:01am
It used to be they all came through marsden point and except for a few possibly useless additives were exactly same. I recall someone testing them and found no difference. Challange imported own at one stage and was tested as having higher real world octane but then they stopped getting their own. Has this changed? I hear gull does own but as you say we don't get this down south. Isn't all the 95 the same stuff?
bill-robinson,
Feb 12, 7:02am
to many variables to give a positive answer to ths question
elect70,
Feb 12, 1:36pm
Chalenge bought by Caltex but Challenge give 8c /l discount to super gold card holders , only discovered this when i filled up at servo usually use Z
mohaka,
Feb 12, 2:15pm
I used to work for an oil company and in those days all petrol was the same when it arrived on the ship,each company took their quota. The only difference was the percentage dilution /or if they blended "slops"(got rid of-pipeline flushings-things from diesel, propylene glycol,M.E.K.,alcohols to Vinyl .Acetate.Monomer) into the bulk car fuel storage tanks.Smaller outfits that did not bring in solvents therefore had the purest fuels.
timmo1,
Feb 12, 2:16pm
If you are tuning to a point where there is a difference between the brands, then you are probably getting a bit close to the edge.
Generally speaking, obtain your fuel (esp high octane) from a source which has the greatest throughput (i.e. the 'freshest' fuel which hasn't been sitting in the tank a long time)
mrcat1,
Feb 12, 5:35pm
It all comes from the same place, just different additives, BP 98 comes from Singapore as well as Gull 98.
martin11,
Feb 13, 9:44am
Probably dreaming that the is a difference as even the local air pressure , altitude and temp will alter power ratings
inkapuka,
Feb 13, 10:49am
Lol nah i was just curious if fuel brands were different but thanks for the info
patxyz,
Feb 13, 11:00am
Caltex has little men that clean your engine in their petrol, so I'd say theirs is best.
twincam1,
Feb 13, 11:02am
Put it on LPG, 105 octane
neville48,
Feb 13, 9:46pm
Caltex and BP are the same real petrol, Z is a bio-fuel so has ethanol added. In saying that we use a lot of BP 95 and find it changes in quality quite a lot unlike the 98 which is quite stable.
neville48,
Feb 13, 9:48pm
Is Gull 98 a bio-fuel with added Ethanol or does it pump as it is imported.
martin11,
Feb 15, 6:23am
neville48 wrote: , Z is a bio-fuel so has ethanol added./quote]
Not in their Petrol ,possibly in their diesel
bumfacingdown,
Feb 15, 8:05am
" Z is a bio-fuel" Not according to the Z website
clark20,
Feb 15, 9:36am
In some US states the same "rated" fuel changes to suit outside weather, mainly in places were it can be -20 to +30 degrees. In the cold won't start or too hot goes off.
len_f,
Apr 2, 6:32pm
I used to unload oil tankers at Seaview near Wellington once the tanker started pumping and the correct valves were opened ,the petrol went to the storage tanks of the following oil companies mobil,shell ,caltex,,bp all recieved the same petrol you might wonder where and when the additives are added
Apr 3, 6:03am
ethanol is the stuff with e on the fuel and should be avoided its gull who sells ethanol fuels . Gull Force 10 its 10% ethanol a sure way to destroy any engine and fueling system unless its a flex-fuel vehicle and even they can suffer problems when you get a ton of water in your fuel tank . ethanol binds water its how you test for amounts of ethanol by adding water shacking the fuel and then mesuring how much more water you now have , as ethanol binds to water and seperates off the petrol.
tony9,
Apr 3, 7:23am
Yes, but those little men can get stuck in the injectors.
BTW, the "little men" additive will not have anywhere near the energy density of raw petrol - therefore less power per litre.
dave653,
Mar 31, 4:02am
Did a lot of testing with various fuels/octanes some years ago after 'playing' with different zorst systems. I found Shell 96 (now 95) was the best all rounder, and still is. BP feels flat, Caltex is uneconomical, Mobil is almost as good, but not quite. Gull up here doesn't have 95 anymore.
