REV Count
clothesline2011, May 26, 9:19am
I have a Honda odyssey and today when it was in park it was like it was trying to find the revs a going up and down, but as soon as in Reverse drive etc to was ok. Its the 1st time this has happened. Any ideas what could cause this
m16d, May 26, 10:23am
Was that straight after start up from cold. It'll come right when it warms up.
franc123, May 26, 10:26am
It shouldn't be doing it at all. Have you checked the coolant level lately OP?
clothesline2011, May 26, 10:32am
it was super cold this morning but i dont think it was that as i drove to school the to doc and then it started that once in park. ok in drive and intersections etc, then did it again whn i parked in dirveway, i will look at coolant level too
andy61, May 26, 11:50am
Often the throttle body(part of the air intake system)get dirty with age and mileage and cause revs to hunt, get the throttle body cleaned and should run better.
clothesline2011, May 26, 11:54am
thanks i do that too :)
pandai, May 26, 12:20pm
Which year, late 90's four cylinder model? It might be the idle air control valve, those can get clogged with age. if you have the engine I'm thinking of it's on the front of the intake plenum with a wire plugged into it and coolant lines running in and out.
brapbrap8, May 26, 4:24pm
Air conditioning/heater turning on and off will often make the revs go up and down while parked. Turn the fan off and see if it still does it.
gmphil, May 26, 4:37pm
haha got a box once off a mate turn the air cond off grab the box of the seat same time lol
clothesline2011, Sep 14, 1:37pm
it only does it sometimes and yes a 94 honda. air conditioning/heater is off
