i have a 1999 nissan terrano running the ZD30DDTI motor in it, when i was driving it today the engine light came on and then the ext started rising so i pulled over and turn the truck off and it cleared the engine code but then did it again, what would be causing this? Would be a great help cheers.
Jul 20, 4:18pm
ummm yea did you actuarly write down what the code was? also i dont even know vw or fiat engine codes i got better things i need to fit in my heads memmory . what is this petrol diesel cc rating and what did you clear the codes with global obd2 junk or a nissan consult? i hope you wrote the codes down befor you erased em?
casper35,
Jul 20, 4:22pm
its a 3L turbo intercooled and all i did was turn the key on and off 4 times and that stopped the light
Jul 20, 4:24pm
diesel ? and what is that suposed to mean i dont understand your english sorry ext started rising ?
casper35,
Jul 20, 4:26pm
yep diesel was meant to say egt = exhaust gas temperature
morrisman1,
Jul 20, 4:29pm
Air flow meter is common on those isn't it? would cause overfuelling and on a diesel doesnt that increase EGT? Im only guessing here
casper35,
Jul 20, 4:31pm
yea that could be something i could look into cheers
Jul 20, 4:34pm
and how exactly did you determen the exhaust temperature did rise? did you look for blocked exhaust ? also the light stays lit when the computer finds something outside the window of operation during 5 continues checks, the problem wont be gone if the light is out it just means it has not seen it fail 5 times in a row
Jul 20, 4:37pm
you need to pull the codes with a factory level capable scanner . launch-tech will pull any code on a nissan . for diy i do not know if the diy-consults cover diesel what plug do you have exactly the obd2 or old nissan square plug or both?
casper35,
Jul 20, 4:50pm
i know the temperature increased because i have a gauge telling me and also it has the square nissan plug
dont damage pins in connectors and dont fry the ecu- if its to hard take it to a big main nissan dealership and have the code read out with factory scanner. i use T pins and a scope to test sensors , i am sure the manual has coverage how to get codes out you can look and post what page it is on i dont want to do your work also.
Jul 20, 5:36pm
i could not let it go lol page 36 has self diag dont spread pins use suitable pins to jumper as per distructions . also irregular blinking check engine light drain water from fuel-filter also somwhere there . so i got to whatch some training movies now i am done with helping you for tonight . make a movie of the bulb flashing before you erase codes so you know what they are .
xs1100,
Jul 20, 5:47pm
those motors known as hand grenades with the pin missing anyway
andy61,
Jan 17, 3:01am
You asked about these Terranos on july 5, had you already purchased the Terrano?, or did you go against everyones advice and got one ?
