Ball Joint
bjmh, Sep 18, 6:17am
Had a guy come in yesterday with a 2003 Hilux 4wd ute,said it had a noise in the right front,the lower ball joint has rusted the top out and popped up ,to try and mill its way through the cv joint.Vehicle stiil had 6 months of a 12 month wof left.I will try and post a pic .
robotnik, Sep 18, 6:24am
Can you tell if the part is genuine Toyota, or aftermarket?
saxman99, Sep 18, 6:25am
Crikey. I believe that part has reached it's mechanical limit.
macman26, Sep 18, 6:31am
Is that the bolt at the top to unscrew and put a grease nipple in? Guess no one has ever thought of that if it is.
I remember crawling under my cars twice a year to grease uni and ball joints.
kazbanz, Sep 18, 6:44am
Sorry matey Im missing the connection between a part failing and the WOF being 6 months from being needed.
I could be wrong-(have been many times before according to mrs kaz)
But it looks to me that the part could have failed one day after a WOF even minutes after a wof.
--or am I seeing the break wrong?
The fact it was milling its way into a CV comes down to idiot owner surely .
bjmh, Sep 18, 6:49am
bjmh, Sep 18, 6:53am
I was probably only trying to point out to people who have a current wof,that a piece of paper doesn't make a safe vehicle.It shows what corrosion can do as well as wear.
kazbanz, Sep 18, 6:58am
sweet as bro
3tomany, Sep 18, 9:14am
I had a hilux surf and can tell you those ball joints do not last long, i forgot how many we replaced it seemed like every wof was a different joint
sr2, Sep 18, 9:44am
LOL; in the "old days", (que the violin music in the background) we would unscrew the grease nipple, pop a small ball bearing down the hole, fit the nipple and tighten and then drive very slowly to the local testing station. !
budgel, Sep 18, 9:46am
If the ball joint is that rusty what does the rest of the underside of the vehicle look like?
bjmh, Sep 18, 10:57am
actually didn't look bad
bill-robinson, Sep 18, 11:00am
just proves to me that the country needs a WOF system. maybe it should be shortened each time the vehicle fails untill the owner gets the message
maitainence is not a dirty word but does replace she'll be right
ema1, Jun 14, 3:26am
Had that been parked in the sea(salt water) or a salt works like Lake Grassmere by chance, that's diabolical corrosion in there? I'd be looking at all the joints and even going through the rest of the vehicle with a fine tooth come if I were you?
