Help pls . Can't find anchor points
danitza, Jul 2, 8:12pm
Hi there, any idea where can I find the anchor points in a Hoda fit 2004 , I need to install 2 baby car seats.
Thanks
missing1, Jul 3, 8:13pm
Not all vehicles come with anchor bolts so you may need to have them installed. About $20 to buy from SuperCheap autos then installed at local garage. My local charges $30 if you supply the bolt or $50 if they do
skin1235, Jul 5, 5:02pm
won't someone think of the kids!
seems the manufacturers already have, they produced a car that cannot have kids onboard as factory fitted
putting kids in a fit is setting them up for a life of fits, poor things
won't someone think of the kids?
skiff1, Jul 5, 8:55pm
what is the bolt made from? Unicorn crap? $20 for a bolt is bloody cheeky.
intrade, Jul 6, 7:12am
well i dont know if i would even put my name on installing a bolt as anchor point in some car my self probably not because of who they come to should the car be ina accident and the seat not holding .
Personally i would find a seat that buckels to existing rear seat belts and have the seatbelt inspected and renewed if they are old they hold on factory anchor points for my kid if i was phisaclly you with a flick of a switch like in them movies.
grangies, Jul 6, 8:08am
I think you may find the anchor points are on the actual rear seats themselves somewhere and not necessarily on the floor pan.
Is there a little removable pad that sits between the base of the seat and the backrest? Either accessible from where you sit, or in the boot area at the bottom of the seats?
stevo6898, Jul 6, 6:38pm
That's what I was thinking. Gotta be some fancy bolt.
ianab, Jul 6, 7:35pm
Not sure on the Honda, but our 04 Caldina doesn't have them. Just use the seat belt restraints. My 07 Blade and Mum's 14 Corolla has a little fitting on the back of the seat that takes the kiddy seat back restraint. Because hatchbacks and wagons have the fold down seats and no solid parcel shelf behind the back seats makes it hard to fix a seat restraint to anything more solid than the back of the seat.
jason_247, Jul 6, 7:45pm
they are a high grade bilt but also comes with high grade washers, spacer block and the metal piece that they clip onto.
dinx, Mar 18, 4:36am
Check the manual firstly, I think they are tether pointe in the ceiling in jazz/fit, but you still need the bolts. I'm last that stage but had to look up location for my Mitzi and was in manual.
