Aftermarket coil springs
gmphil, Jul 7, 12:34pm
king, dobi in others !
anybody body have any recommendation as to who is better product ?
or are they much or a muchness ?
mack77, Jul 7, 8:08pm
When I wanted a set of raised springs for my old AWD Honda Odyssey my research indicated that the best brand was Cobra. I bought them direct from the manufacturer in Christchurch and got excellent service from them. They are performing to my expectations and were very reasonably priced. They were delivered overnight, as they were available ex stock, much to my surprise.
pico42, Jul 7, 8:51pm
What do you want to achieve with them? Lift? Lower? Stiffer? Softer? Other?
clark20, Jul 7, 9:05pm
gmphil, Jul 7, 9:36pm
need a pair of springs for a conversion want a low .
as far as stiffness would like to handle as mint as it can but defiantly don't wont a bone breaking ride !
have bein email suppliers for there specs ,had a few replys .
so far seems I have two options
1st 280mm free height 670lbs standard low v8
2nd 265mm ^^^^^^^^ 820lbs upspec low v8
am wondering how much stiffer better the second option will be !
bill-robinson, Jul 8, 5:59am
what rate are the original springs?
bill-robinson, Jul 8, 7:53am
while you are at it what is the free length of the original spring? and the fitted length on the car sitting on the ground?
gmphil, Jul 8, 10:59am
4 maybe 6 cyl springs were in it . have discovered v8 motor 250kg
gmphil, Jul 9, 10:06am
with the amount boy racers lowered cars I see round and the massive amount of rebuilds I read about thought would of got more response's lol .
cobra could be it then and in nz altho they hav not returned my email on specs of there spring only aussie crowds !
bill-robinson, Jul 9, 10:49am
you asked for help.
I asked for information to help you
I have yet to see a usable reply
gmphil, Jul 9, 2:06pm
sub frame is out for cleaning painting a arms are off for new bushes
springs were/ are 40 years old rusty and cut too so I discovered when pulled out .and have bein binned so cant help as either diamention u asked for be wrong ? being old saggie and cut .
maybe able to get from supliers spec on origjnal would this help bill?
bill-robinson, Mar 2, 11:07am
find the correct info and post it on here
if it is 40 years old why do you want to lower it?
