Tachometer
elect70, Sep 10, 12:56pm
electronic in my rangie stopped working . How can i test it , should it have 12v on 1 side & a pulse on the other . manual doest show engine /intsrument wiring .
intrade, Sep 10, 1:42pm
It be most likely pwm signal on off don't screw the instrument most like 5 to 7 volt on off like wheel speed sensor signals
tony9, Sep 10, 2:04pm
What year? And is there anything else at all that is not normal?
intrade, Sep 10, 2:16pm
yes his ecu is fried probably from a shorted injector .
What exactly do you hope to do now convert it to not have a ecu?
elect70, Sep 10, 2:49pm
^^^ Yeah right carb./manifolds fo the 3.5 rarer than rocking horse poo . Serious Off roaders snap them up Replaced ECU 89 RR engine fine just tach doesnt work ECU had a fried diode pack due alternator had rotor short . Can get tach from wrecker but rather test it first .
tony9, Sep 10, 3:30pm
Rev counter in your car comes off the back of the alternator. How did you fix your alternator?
If the alternator does not have the "w" terminal then you are sol.
bigfatmat1, Sep 10, 6:38pm
Did you connect the wire back up to the correct terminal on back of alternator?. as above should go to "w" if you are replacing tac make sure it's suitable for diesel driven by alt.
intrade, Sep 11, 9:34am
did he mean the rev counter ?as the tachometer is for speed might have mixed it up as its called the tacho in german haha.
if its the rev counter i would wire in a boy racer aftermarket one . as cheaper option.
elect70, Sep 11, 12:25pm
Brand new alternator OEM Lucas replacement , the pulse for the tach comes from the - side of the coil & also feeds the ECU , plenty of used ones around but just wanted to be sure its fried .
tony9, Sep 11, 12:43pm
Are you sure? This should be your RR circuit, 9 is the Tacho, 11 is the alternator.
https://trademe.tmcdn.co.nz/photoserver/full/409501792.jpg
bigfatmat1, Sep 11, 12:43pm
Well if it's a pulse from neg of coil only other wires is pos and neg. Check power and earth and continuity to coil
tony9, Sep 11, 1:00pm
elect70, Sep 12, 1:26pm
^^ ah yes white wire left off the alternator it was supplied & installed by mech at garage , methinks he has put in a non rev counter early type alternator , no connection for it . off to see him monday . Paid the C enough
elect70, Sep 19, 12:15pm
I Worked it out that as its 3 phase ac rectified to dc then taking wire from 1 phase would give signal each revolution . did it & walla rev counter works again ,.
lookoutas, Sep 19, 4:50pm
That was a good thread and outcome - plenty of genuine advise and I didn't understand a bloody thing.
tony9, Sep 19, 5:29pm
Was going to suggest that, but was going to do some research first. Don't forget that the alternator stator will be quite happy to put out something over 40 Amps and your tacho wire won't be up to that if the tacho end shorts. I would try a 10K resistor close up to the stator winding.
bigfatmat1, Jun 5, 8:31pm
Yep thats it just a stator tap. its exactly what the 'w' (winding) terminal is. Just easier. Pretty poor on sparkies part to leave it off.
