I'd probably keep the halogen bulb's / fittings then swap when wof is due in a few yrs time.
jason_247,
Jun 21, 5:08pm
Totally legal. You could save a shit load by using standard led replacement bulbs from supercheap and putting a resistor inline to stop error messages. but otherwise these will be fine
Only ones that get pulled up are red amber of blue bulbs facing forward.
underglow lights are legal if they dont flash and the source cant be seen from directly forward of behind, i.e. tuck them away so you only see the glow.
tweake,
Jun 21, 5:09pm
not that i know of. had led bulbs fitted for years. used red ones to get around the fading lens problem.
clark20,
Jun 22, 9:46am
Totally illegal if used in approved light fitting (headlamps etc). They have to comply to standards, and they don't. The approved bulbs are those listed from the manufacturer for the lamp.
kevymtnz,
Jun 22, 10:46am
reversing i find fine but if you have them in the front and dazzle me yr gonna get full beam from me legal or not
mycool87,
Jun 22, 12:35pm
lucky I've got anti-dazle rear view mirror.
jason_247,
Jun 22, 1:24pm
Do you have a law to support that or are you just pulling an opinion out of nowhere?
I doubt the op will be putting number plate or reverse bulbs into a headlight.
inkapuka,
Jun 22, 4:24pm
You dont need reverse lights for a wof so can be any colour you want pretty much my cars lights all are led apart from headlights high and low beam interior and exterior so much brighter and last a lot longer
clark20,
Jun 22, 4:58pm
yep , law as I practically wrote it for the LTSA (back then). If you change the light source you are modifying an approved lamp so it is a modification. The modification also has to then comply with the standards. Just because people get away with it does not make it legal.
marte,
Jun 23, 6:07pm
I thought blue bulbs of any sort were illegal because the police use red/blue lights.
I saw a car with blue numberplate lights yesterday, got me wondering.
