1997 golf gli
afer_daily, Jun 30, 1:18pm
how sensors in the cooling sydtem / i know the one in the radiator but ive been told theres another one /and where is it / niether of the cooling fans are going ?
intrade, Jun 30, 1:54pm
is this got aircon or not?
also the mk3 still or mk4 platform? should be a mk3
afer_daily, Jun 30, 2:21pm
aircon / mk 3
intrade, Jun 30, 2:22pm
vw usually have good support for technical stuff if you look for it , mazda on the other hand is the worst nightmare you could think off.
http://www.deylan.co.uk/golf/ from the link above http://faculty.ccp.edu/faculty/dreed/Campingart/jettatech/
within that site also learn how to read german wiring diagramms
http://faculty.ccp.edu/faculty/dreed/Campingart/jettatech/acwork/index.htm
intrade, Jun 30, 2:24pm
turn on aircons fans must come on with aircon check aircon compressor works or it could be the aircon system who shut the fans down. Could needs investigating . my vw turns fans on but aircon is not working when i use aircon have compressor unpluged till i can get somone who sleeps with his aircon manifold gagues to have a look at it. my one is mk4 sedan golf=bora or jetta.
jmma, Jun 30, 2:31pm
Is that because you need to repair VW's more than Mazda's :oP
intrade, Jun 30, 2:33pm
looks like the mk2 thermal switch in radiator jumped. the mk1 only has 2 pins i used to have a jumper in the glove box to jump the fan if it was not going to come on on hot days in traffic
afer_daily, Jun 30, 2:38pm
body num wvwzzz1hzvw472104 eng iop 0483838de 46rnz96 . i think ?
intrade, Jun 30, 2:41pm
just jump the wires and see what happens as per swaptron distructions solong as the wire colours mach what he writes there.
intrade, Jun 30, 2:48pm
IF THE COOLING FANS DO NOT WORK:
Well, here's a fast test. The Fan should Should have these colored wires:
Brown (ground)
Red/White (low)
Red/Gray (high)
Locate the fan sensor (drivers side, near headlight, in rad. ) its a 3 wire sensor.
It should have these wires:
Red +12V from fuse 19, 30A under dash
Red/White (low speed trigger)
Red/Yellow (high speed trigger)
Check All fuses under dash. 19, 6 and 4 are key as well as a brass colored bar on the coolant module.
Anyhow. On the fan sensor, unplug it, and jump with a paper clip:
RED to Red/White (fan should come on low speed)
Unplug it. and then;
RED to Red/Yellow. (fan should work on high speed)
IF THE FAN RUNS REPLACE THE SENSOR IN THE RADIATOR.
IF the fan DOES NOT come on jump power TO THE FAN.
IF THE FAN RUNS when jumped directly to power:
Replace FCM.
If fan does not work replace fan motor.--
intrade, Jun 30, 2:52pm
so jump Brown (ground) To Red/White Slow speed fan
or jumper wire Brown to the Red/Gray wire for fast fan speed.
its ground side switched the switch is inside the radiator when the cooling water gets hot enough
so if the radiator dont gets hot enough the fan switch also wont trigger bend the bimetal inside the switch to jump to one of the 2 wires.
jumping the wire is called a bypass test use what ever but dont damage the pins . paperclip short wire what ever suits
i had a short wire with 2 spade consctors in glove box on mk1 golf
intrade, Jun 30, 3:01pm
afer_daily, Jun 30, 3:16pm
thanks will try it tommorow / and see how it goes
afer_daily, Jun 30, 3:18pm
one more question FCM ?
intrade, Jun 30, 6:01pm
fan control module .
afer_daily, Jul 7, 7:43am
to all those that helpd /thanks . it was the radiator sender unit . but bleeding the cooling system was a b@sted of a job but got it done ! the temp readings are now good / around town temp is half way / 100 d and motorway is 70 d . am now one happy driver .
intrade, Mar 16, 8:25pm
yea easy as on these old swaptronic cars.
