Would you buy a aftermarket
fordoverholden, Apr 29, 3:44pm
timing belt kit? for a toyota 92,
jmma, Apr 29, 3:49pm
Yes, but price up at Toyota as well, they have good pricing now. (o:
fordoverholden, Apr 29, 3:52pm
sw20, Apr 29, 3:53pm
No I wouldn't. Genuine parts are not expensive. $200 would get you a cambelt, waterpump and tensioner from a dealer.
kazbanz, Apr 29, 4:03pm
actually I might well do. The reason being the gates belts are more oil resistant than factory so with an older car might be worth while
phalanax, Apr 29, 6:04pm
I would buy the real mcoy from the dealer. timing belts a critical part . I might buy brake pads or wiper blades elsewhere.
thunderbolt, Apr 29, 6:09pm
The real Mcoy?
Do you think Toyota makes their own timing belts?
bwg11, Apr 29, 6:55pm
No. But from experience, if it failed prematurely, there would be much more chance of Toyota covering the damage than Repco covering an aftermarket part.
grangies, Apr 29, 7:08pm
LOL. Toyota aint gonna cover nothing for a 1992 vehicle.
thunderbolt, Apr 29, 7:09pm
That is the exact opposite of the truth.
OE warranty is 12 months in most cases.
Gates warranty is service interval replacement ( recommended replacement interval) and covers parts, labour and damaged caused by part failure.
snoopy221, Apr 29, 8:59pm
The question really is buy Gates- or buy O E M-Which very often IS Gates.
elect70, Apr 30, 2:24pm
^^ exactly OEM could be Chinese knock offs , at least Gates is a well known & trusted brand .
gsimpson, Apr 30, 2:40pm
I have been using $20 Gates belts on my Lotus Esprit for years without a problem. The current specs for these belts is above that of the OEM belts when the car was new.
fordoverholden, Apr 30, 4:30pm
STA parts. Has anyone ever had issues?. that is where im buying it from.
thejazzpianoma, Apr 30, 4:42pm
I too am happy with Gates belts, if they are good enough for our Alfa 156's and the like (which are very hard on timing belts) then they are good enough for your Toyota.
I would personally be more worried about what waterpump and tensioners you get. Those are both items that I have had trouble with, with aftermarket brands. So make sure you are getting a complete Gates kit or at least a known good quality brand pump and tensioners, as sellers will often supply tensioners and waterpumps seperately.
Best of luck with it.
pc_uncorrect, Apr 30, 5:14pm
Replaced neighbours mazda demio timing belt with an aftermarket 'optibelt', 10,000k so far so good.
jmma, Apr 30, 5:40pm
What is the milage of your '92 Toyota and what Model?
fordoverholden, Apr 30, 5:46pm
232000 sprinter marino. just no indication when it was last done. dam it
fordoverholden, Apr 30, 5:48pm
this guy has a complete kit. from STA parts. have you heard of them? cheers
sparkyz, Apr 30, 7:31pm
Have heard good things about the DAYCO kits from BNT.
phalanax, Apr 30, 7:50pm
I know this much, some cars dont run that well with a clone timing belt . Some hondas and mitzis in my experience. also came across a Vitz that was running a clone accessory belt and it was vibrating the alternator very slightly made the engine sound as if it was knocking. changed the belt to factory and it fixed it. personal choice
snoopy221, Apr 30, 9:25pm
`NOTE- S T A IS Segedins been around for yonks
http://www.staparts.co.nz/
Damn good-after all most decent engine reconditions use em
72xu-1, Feb 18, 1:43am
Toyota genuine parts are Chinese knock offs - are you serious?
