Hi people- Just a quick question. The car is an older 1989 Nissan Pulsar with the GA15S carb petrol. I used 10W-40 last time but feel it is a little thin on start up so I will be using 15W-40 this time. For an older motor such as this (with low kms and doesn't use and oil) should I be using mineral or synthetic oil? Or doesn't it really matter for this type of car? Cheers
Jul 19, 5:50pm
Stick with mineral, adding synthetic at this stage in its life could be disastrous if its got any degree of sludge buildup inside. Being thin on startup isn't a problem, you want good oil flow when its cold. If its not consuming any oil or isn't rattly when hot I would stick with a good quality 10W/40.
m16d,
Jul 19, 5:51pm
Just remember that on start up on a cold morning you don't want oil that's thick as marmite.
