Bogging up metalwork
trade4us2, Jul 20, 7:00pm
It's not a car but I'm sure people here will know.
I have a large copper lamp that is very beaten up. I want to paint it black.
What do I fill the hollows with before painting?
It looks a bit like this but is much more beaten up.
https://trademe.tmcdn.co.nz/photoserver/full/396624695.jpg
I have bog with hardener, but I find that's hard to spread flat.
I also have Selleys Permafilla. I don't know if that will last OK in the weather.
joanie32, Jul 20, 7:04pm
Careful, they are actually worth good coin. If you don't think you can do it properly.
trade4us2, Jul 20, 7:14pm
The lamp has been altered from the original, with steel rods that have rusted away. I have replaced all the steel with copper rods, and replaced all the copper clips that hold the glass in.
I usually do a fine job of metalwork, but have not done a lamp before.
gammelvind, Jul 20, 7:18pm
Go to your local auto repair supply store and get a can of puttycote.
http://3mcollision.com/products/fillers-and-glaze/putty/dynatron-putty-cote-592.html
Easy sanding and applying, this should do the job for you.
trade4us2, Jul 20, 7:55pm
Yes something like that looks good. The guys at work may have something, since it's their job to paint things.
kazbanz, Jul 21, 7:27am
If it genuinely is made of copper then I wouldn't be bogging it at all.
Copper is a lovely material to work with so I would be taking the lamp to bits and massage it back into shape. Use lots of smaller/lighter taps with the hammer and you will be amazed at the results.
trade4us2, Jul 21, 8:06am
Here's the lamp at the moment:
https://trademe.tmcdn.co.nz/photoserver/full/398433813.jpg
It's had years of painting and alterations. I have removed all the rusty steel and soldered it back together with the aid of a wooden jig to hold it in the right shape.
It would be quite a job to polish all that but I could try. If I polish it then someone will probably steal it and melt it down.
There are half a dozen other lamps that are painted black and are not copper.
lookoutas, Jul 21, 5:08pm
Just use the bog you've got.
Don't try and spread it flat - put it on a bit proud and sand it flat.
trade4us2, Jul 21, 5:48pm
I might polish the copper. I can always paint it later.
I have made this out of some scrap copper and some 50mm brass rod:
https://trademe.tmcdn.co.nz/photoserver/full/398436359.jpg
trade4us2, Jan 10, 5:33am
I polished the top bit.
https://trademe.tmcdn.co.nz/photoserver/full/398837556.jpg
I'll polish the rest.
