Vc valiant
afer_daily, Jan 15, 10:39am
radiotor pressure cap / what max poundage would be best / and for that matter whats the lowest you could get away with ? thanks
jmma, Jan 15, 11:02am
14 PSI is the recommended one, What is the reason for a lower one ?
afer_daily, Jan 15, 11:07am
got a slight leak in the top tank / have stuck rislones magic muck in / still a small leak / but its running a 16 pound cap at the moment ? thanks
skiff1, Jan 15, 12:42pm
You could get the radiator patched? Seems like a hell of a risk to take with an older car potentially worth a bit of money?
jmma, Jan 15, 1:39pm
Put some grated soap in it, cap half on for awhile, all fixed (o:
whqqsh, Jan 15, 2:04pm
that stuff they sell at Repco, Autostop etc works like a charm, its a 2 bottle mix of what smells like superglue in one & crystals in the other, seals up or joins everything Ive tried it on including a hard to find radiator hose that was leaking at the T junction, one year & still going strong.
afer_daily, Jan 15, 2:55pm
like i say ive put some rislones stuff in ($27 ) and a 13lb cap will see how it goes / planning going to Kumeu on the weekend . thanks guys
ceebee2, Jan 23, 7:01pm
They have a copper radiator that is usually quite an easy fix so long as it isn't the core.
