What size rim?
haventrader, Oct 26, 11:41am
I have a van with 205/60/R14.5 tyres. The rims are tired so want to replace them with alloys. What size rim is suitable? 14"?
Cheers
tamarillo, Oct 26, 12:39pm
Unsure what the 14.5 means, never seen a decimal their so assume you mean 14. A 205/60 x14 tyre goes on a 14 inch rims 5.5-7.5 wide.
http://www.lvvta.org.nz/documents/infosheets/LVVTA_Info_01-2009_V2_Tyre_Size_to_Wheel_Size_Compatibility_Guide.pdf
haventrader, Oct 26, 1:09pm
Cheers, it is indeed 14.5. It is unusual but apparently quite common on vans?
gpg58, Oct 26, 1:32pm
https://trademe.tmcdn.co.nz/photoserver/full/421000617.jpg this site will help you decide, as i understand it you are allowed + /_ 5% without a cert. Remember to choose a Tyre with the right load rating for your van. http://tinyurl.com/prom8xv
gpg58, Oct 26, 2:23pm
the question is, will a 14 inch rim fit over your drums or discs/calipers. if you search forums for your brand of van, someone will know what goes on.
To put 16's on my holden aventra (crewman), a aussie site told me the steel wheels off a early bmw roadster were the correct offset to clear my discs, worked great and improved ride truckloads.
michelle322, Oct 26, 4:35pm
being a 14.5 rim,i presume that is the rear rims only and the front are standard 14"or so, the rear tyres would be a super single that would have replaced two rims[dual tyres each side]so the stud pattern probably wont fit mags
haventrader, Oct 26, 5:27pm
All the tyres are the same, and the original did not have dual rear wheels. Wheels can be / have been rotated.
lookoutas, Oct 27, 6:30pm
It sounds to me like you've got some of those metric wheels.
Chuck the B's away and get some 15's.
If 14's fit over everything with the right off-set, then go for them if you want
Be a great help to know what colour the van is!
haventrader, Oct 29, 8:23pm
Colour? Not sure how that relates but off-white, with go-faster stripes. Thanks for the advice though.
ralphdog1, Oct 30, 11:33am
That went thru to the goalkeeper.
thunderbolt, Dec 17, 7:02pm
I thought it went over the crossbar, way over
