Keep blowing 9" diffs.
bill-robinson, Mar 19, 6:46am
put some diff oil in it
jmma, Mar 19, 6:48am
Long time no see, try fish oil (o:
whqqsh, Mar 19, 6:56am
are you sure its 9" 'diffs' you're blowing? doesn't have anything to do with kneeling down does it?
richardmayes, Mar 19, 7:01am
Your engine is simply too powerful for a 9" diff.
Congratulations, you are the alpha male, you win everything.
car27, Mar 19, 7:10am
Is it the angle of the pinion in relation to the driveshaft when the power comes on
mechnificent, Mar 19, 7:20am
What breaks ? Crown-wheel or pinion, or spider gears ?
If it's the side/spider gears, then too many wheelies.
If it's the crown-wheel/pinion then perhaps set up is not good. perhaps the contact area is too high on the tooth.
If you are only breaking diffs and not axles then something must be wrong huh.
intrade, Mar 19, 7:20am
well what do you actuarly do replace the diff heads? because doing that and incorrect instalation can lead to soon distruction. differential are one of the hardest things to correctly repair and replacment with a knowen good part and eliminating the actuarl problem that caused the diff to blow up to start with is also a good idea. . -
mechnificent, Mar 19, 7:40am
When do they break, what are you doing at the time ?
And have you broken any axles ?
mechnificent, Mar 19, 7:43am
If you've got enough torque to break diffs, then I'd expect you would have broken a few axles as well, and I'd suspect the diffs and axles would be breaking as you drop the clutch as well.
If the diffs are breaking, and we really need to hear which part is breaking, during driving, then something is wrong, and it's not too much horsepower or torque. disappointing though I'm sure that is going to be to you. haha
bjmh, Mar 19, 7:54am
do what the idiots around here do,weld the spiders up. then the wheels can fall off.
floscey, Mar 19, 8:11am
to much grip around top of the shaft by the looks. Designed by wankel driven by wanke
whqqsh, Mar 19, 8:21am
aha! so my original suspicions were correct then
bjmh, Mar 19, 9:31am
I guess it beats Seals !
jason18, Mar 19, 2:28pm
Something smells very fishy. I miss Audi
beno, Mar 19, 2:49pm
put skinny wheels on the back. that'll fix your problem
purple666, Mar 19, 3:17pm
Ahh that explains all the lipstick over my rear end. And here was me thinking I must have been parking on hookers.
snoopy221, Mar 19, 9:05pm
patiki1, Mar 20, 4:24pm
He does this every year,under a new name
snoopy221, Mar 20, 4:34pm
sr2, Mar 20, 5:00pm
LOL, with a user name like that how could you not be blowing 9 inch rears (and fronts to that matter) on an almost daily basis!
mals69, Apr 23, 12:02am
Put some banana skins in it - potassium pulp will harden it
