Options to remove clear coat from chrome
clampits, Dec 16, 10:34am
rust spots starting on wheels under clear coat on steel rims any easy fix other than new wheels
grangies, Dec 16, 11:08am
What makes you sure the chrome has clear coat on it?
clampits, Dec 16, 11:18am
Some of the clear has flaked on the rims and also broken away under the wheel nuts
kazbanz, Jun 11, 11:15am
So the rims are chrome plated steel?
If Theres rust then likely the chrome has split around the wheel nuts and the metal underneath is rusty. That could be darn expensive to fix.
But that is assumeing it is chrome plated steel
