1997 Nissan Cefiro Stationwagon Failed on rust on front cross member (front & rear) Radiator support?
mr_lovebug,
Nov 29, 6:56pm
Depends on who does it and where you get it done.
You might be able to do it yourself and that requires you to find the parts and take the old ones out and fit in the new ones.
Otherwise maybe GUESS $500 or less, depends on the amount of work and hardness you have in accessing the bolts etc, my brothers son had the same problem. Hence it's a common problem.
Nov 29, 7:01pm
Lol it isn't a case of replacing the x member, it requires cutting and a competent welder to fix the panel it attaches to, its a bitch of a thing. Failed an A33 sedan for that problem only last week, you'd hope 4-500 would cover it.
jake74,
Nov 29, 7:09pm
Bugger heading down to Dunedin in 2 week and wanted to sell it. Maybe off to the wreckers instead
jake74,
Nov 29, 7:33pm
Would it be better to $1 reserve it on here and see what I get?
jmma,
Nov 29, 7:40pm
Might pay to mention that in your ad. (o:
Nov 30, 8:17am
Jake--its actually becoming quite a common fault as those cars are getting to 20 years old. The inspectors know EXACTLY where to look. The cost will depend on the extent of the rust. I would personally be lifting the car up ,removing the under engine trim and doing a good sandpaper/wire brush cleanup to establish where you are at ie how bad the damage is. last one that caught me out was a $500 repair
rpvr,
Dec 1, 11:19am
And that's at dealers rates -us mere mortals would probably pay twice that.
Aug 16, 11:17am
Nope I wouldn't think so-maybe 10% more
