Could someone please advise if a 2010 FG XR6 has a limited slip diff as standard fitting or not. I know Ford used to have a tag on the diff filler plug saying LSD but cant get under the thing in the garage to check it. What are recommended oils for the diff ?
The VIN plate in the drivers door frame will tell you what factory diff it has/had. Or you could jack up the rear end and see if both wheels turn . Or you can wait until franc123 gets home from working on Fords all day .
monaro17,
Nov 11, 7:55am
Yes they did. Only the xr6, xr6turbo and xr8 had an lsd. As stated above g6et does not
yogibearz,
Nov 11, 8:06am
I thought the XR6 turbo had LSD not the non turbo. Will see what franc123 says if he comes along at some stage. thanks for comments so far.
monaro17,
Nov 1, 12:27pm
Yes you are correct I was mistakenly thinking about the BF range. Although optional quite a few had the lsd.
