am thinking of getting 2 LED spotlights to fit on my utes nudge bar but cannot find anything regarding the rules of this.
I am assuming that they can only run with the high beams?
tigger8,
Jun 2, 9:38am
I had 2 LED flood lights on a wagon and got declined for WOF (only worked on high beam) as was told they weren't up to standard so took off and got WOF
xs1100,
Jun 2, 9:39am
far as I knew so long as they operated on high beam only and had a separate switch it should be fine
Just search for ECE LED driving lamps, and find some that comply
elect70,
Jun 2, 11:54am
I had BMW 635 twin headlights , fitted aux driving lights on hi beam only& VTNZ wouldnt give me WOf saying wernt allowed more than 4 lights forward . i went elsewhere & passed
Jun 2, 2:40pm
If you had more than four main beam lights including the spots it shouldn't have passed. You are not allowed six.
stevo2,
Jun 2, 3:09pm
I have a nudge bar on my van and have a pair of Hella driving lights mounted. They have no seperate switch and must be wired to run only on high beam. I also have a pair of Daytime running Lights that will only run with no other lights operating.
elect70,
Aug 6, 4:28am
That was my argument factory fit inner 2 were low beam only & outer 2 hi beams only , so max of 4 on at hi beam but he wouldnt wear it , the other tester intrpreted it same as me
